When using the rectangular or circular buttons to insert bolts/anchors/holes/shear studs, you are limited to clicking one reference beam or plate to put add the element to. It would be extremely useful if there would be the option to add the elements to multiple beams/plates during the same command. For example, if a piece of equipment's anchoring land on multiple beams and the bolt circle diameter is known. It would be easy to select the beams needed, pick the circular button, select the center of equipment, then give it a radius. Currently in the 2017 version of Advance Steel, each individual beam has to be done separately or an additional step of using Advanced Copy.
