Multiple add joints to Joint group (master joint)
There needs to be a change made to the "add joint to Joint group" command so that Multiple joints can be added to master, rather that repeating the command for each joint.
2 Kommentare
that would be one of the nicest things ever :grinsendes_Gesicht_mit_großen_Augen:
It's better up to this year, because the you could use the Spacebar to repeat the last command
Totec_MW
Yes! Please can we have this? It seems obvious that we should be able to do this. Currently the [select new slave, then select master] procedure seems illogical. Why not have it so you select the master first, then just keep selecting all the joints in turn that need to be added to that group?
Of course there are several instances where the 'logic' of the selection sequence is anything but logical, and not always consistent either. Sometimes you just select, other times you need to confirm selection, and the order of selection varies too. Sorry I didn't mean to start ranting! :zwinkerndes_Gesicht:
Idee einsenden
