Multi-Labels for Beams
Improved Beam LabelingImproved Beam Labeling
We need labels for beams to be improved for erection drawings-Piece marks to remain on the left side, Name on the middle of the beam, camber value, shear studs count on top or bottom, shear and moment values at ends.
Similar labeling is done in Revit and it is great.
Ilko Dimitrov
ACBS
1 Kommentar
acbsdesign
Multi Labels at BridgesMulti Labels at Bridges
Here is another example for a possible multi labels use-for bridges-it is very common, and currently this is done manually.
In this case the second label would be an user attribute.
Regards.
Idee einsenden
