MT Profiles linked to models
When working for many clients who each have different company standards etc we can use MT default profiles with different settings for each client.
e.g. different standard hole or weld sizes on drawings, plus many other things.
However, it is easy to forget to set the current MT profile to the correct one - especially when working on several projects simultaneously or making a change on another project.
To make this much more robust, it would be great if we could link a MT defaults profile to the model say via the Project data dialog.
Much in the same way that you can pick a "preferred sizes" profile here.
...then, whichever project you may be working on or switching between, the MT defaults will always be correct for that client.
2 Kommentare
DumitruBerteanu
Status geändert in: Under Review
pinnacledrafting
We ran into this exact problem yesterday. Had to renumber and remake a bunch of sheets. So either your idea of setting it in the profiles, or possibly a model shortcut from the desktop that launches advance steel and the model with the proper profile. Native Autocad already does this for CUI , toolbar and other settings.
Idee einsenden
