More unfolding options with better explanation of the defaults and direct unfolding setting on the object
Hello developers,
It needs an additional default for the unfolding/wrap around of folded beams with circular cross section:
Combination of largest outer and inner contour
It would also make sense if all defaults for the unfolding/wrap around of plates or beams
would get their own category in the defaults. Currently these defaults can be found in General and Drawing general.
And it would also make sense if the descriptions of the defaults also stated which defaults are used for which objects (beams, plates, etc.).
But it would be much more important if you could set how the unfolding should be done directly on folded plates and beams as well as on unfoldable beams.
Regards
Elias
3 Kommentare
bigcarl5000kg
Folded plate is BIG PROBLEM in Advance Steel from the beginning ....
iwafb
Not if you ask those in charge... In any case, they are low priority.
bigcarl5000kg
it's time to change it ... it's a shame for Advance Steel ... so long
Idee einsenden
