There has been improvements in some macros of the welds which I appreciate, so thank-you. There are still some macros that can benefit from more weld control. Some Base plates, stiffener plates, shear plates, to name a few. The Macro "End Plate" has a good example of how the welds should be.
Also sometimes after making a detail sheet, you have to change the weld. You can erase the macro produced weld and put your own in, but when all you have to do is add "TYP" to the tail, erasing the existing weld and putting in a new one seems unnecessary. Please give us control to completely modify macro produced welds in the detail sheets like we can with manual welds.
Thanks.
