Modify Revision date,mark in drawings
Hi All,
I want to add  a request to advanced steel Team . We  have gone through AS2015 to AS2021 .
But we are not able to modify revision date, revision mark in one go in All drawings once it was revision was added  as tekla does.  We have to open every drawing one by one and then we modify the revisions. It is time taking process for big jobs having 1000 of dwg file . If we have this option it will save our time thanks .
@Sebastian_Eiche  . Please look into this..
6 Kommentare
TvdH1981
I don't understand the matter in hand. It always does it automatically. If you select your drawings and revise them from A to B they all go at ones.
ArjunGaba
@TvdH1981  You can make first and all next revision in All drawings at same time But you can't modify revision date, time in the previous revision in one go One has to open the each drawing and change it manually..
TvdH1981
the date also updates when revised.
ArjunGaba
@TvdH1981  it is not possible what you are saying
IR8ASU1
Editing existing revision numbers to multiple drawings in one go has been requested several times over the past few years. Please add your vote to these other requests via the links below.
https://forums.autodesk.com/t5/advance-steel-ideas/better-revision-control/idi-p/8973979
https://forums.autodesk.com/t5/advance-steel-ideas/select-multiple-drawing-files-to-edit-revision-nu...
https://forums.autodesk.com/t5/advance-steel-ideas/please-make-revision-control-clouds-more-user-fri...
ArjunGaba
@IR8ASU1  Thanks for the vote Jim:lächelndes_Gesicht_mit_lächelnden_Augen:
Idee einsenden
