Modification to sizing definitions
When creating a connection and the coping along with it, an option needs to be added. Currently, when using the (K-distance) option, the Vertical value is defined by the secondary member. This doesn't make sense as the Main member would determine the cope size. The other options to choose from have a Main/Secondary version and i feel it only makes sense to add a (K-Distance Main) to the list
Idee einsenden
