Modification of the End Plate Macro
Hello Everyone,
We faced a case where we need to have a gap in between an End Plate and a HSS Square for CJP purpose. We noticed that there is no option to create a Gap which might be interesting.
2 Kommentare
horstbauer6692
Hello Olivier,
you can create a gap between an endplate and a beam by doing two steps:
1. Cut the profil on BKS (UCS) with reduction.
2. Creat an endplate on the shortened profil.
The gap will be the reduction minus thickness of the plate.
I hope I could help :zwinkerndes_Gesicht:
olivier_gervais
Thank you horstbauer,
But we must have weld prep for full pen. and this second cut is not parametric. It won't follow the beam end if we extend the beam... I was not looking for a workaround. But thank anyway :leicht_lächelndes_Gesicht:
Cheers,
Idee einsenden
