Master Slave Connections
Can we get more automated options for master slave connections. When we slave connections, it can be a battle to find the master in the model, can we automate it so that the master would move to its own layer, or the slaves would not show the connection box around the connection?
thanks
1 Kommentar
AleckGiles
HI,
I am not sure why it is necessary to know which is the master joint. If you want to edit a joint you can select any one of them and on the properties page of the Joint Properties dialog box simply tick "Upgrade to master" This joint will now be the master and the old master will now be a slave.
I would be interested to learn other reasons why you might need to identify the master joint if the above is not enough.
Idee einsenden
