Mapping for a lot of parts works great, also for the non-exploded screw sets. To do this, there are records External1 to External4 in AstorBase / MapInternToExtern, which can be freely combined.
An example for screw set:
BOM example - the screw set description corresponds to the designation in the table Management tools / Screws:
It would be great to get the same result = mapping for exploded screw / anchor sets = separate items from exploded sets (eg. screw, washer, nut, ...) in the BOM for different customers. External1 to External 4 are in this case the different customers.
BUT, Advance Steel cannot map exploded bolts and corresponding separate items from the set (screw, washer, nut, ...) for the BOM.
BOM example - the exploded screw set description corresponds only to the designation in the table Management tools / Screws = no mapping descriptions (External1, ...) was taking over:
Many thanks in advance for a solution a.s.a.p.
