Manual Set location of pop-ups
It would be great to have a button that would allow you to set a location anywhere on your screen for all of the pop up boxes to be set to.  For Example I run 2 screens like most people probably and when ever i open the advance properties of something or i open advance joint properties it almost always opens halfway off the screen. I then have to move it before i do anything else.  I am sure it has to do with one monitor having less resolution than the other but it would still be great to have a button that would allow me to set the location of the top left corner of any pop-up that advance steel creates.
I do want to make clear that the pop-up would not be tied to that location just open at the location and then be moved as needed.
1 Kommentar
bigcarl5000kg
Hi @skylinedrafting2 ,
you can set up the position and size of such screens in the data "ASSettings_User.xml" located in:
C:\ProgramData\Autodesk\Advance Steel xxx\XXX
Even if you loose some property window (out of screen), with deleting of this file, will be a new created with default values.
Idee einsenden
