Manual dimension text on bottom views
Hi everyone,
After adding manual dimensions to a bottom view on a drawing, I cannot get the dimension to switch sides after choosing the "Linear, Ablsolute" presentation from the "Dimension chain" panel.
The tool seems to work on front and top views, however on bottom views, the dimensions are placed close to the object and you have to manually move each dimension into place.
Is it possible to have the same workflow as top and front views.
Sorry I forgot to mention that Advance Steel 2018 was being used.
Best regards,
Janet
Graitec Canada
1 Kommentar
haedicu
Status geändert in: Under Review
Idee einsenden
