Manual BOM
Manual BOM
Often times you have weird bolts or items that are not in the model but want to put them on the bill of materials.
Like Grating Clips or some special fastener or washer.
It would be nice to be able to manually add items to a BOM.
Also it would be nice to manually add BOM items attached to an assembly. That automatically print with the part you attached it to.
1 Kommentar
tommy
One way to possibly implement this is create an "invisible" Advance Steel Object. It is technically an object but with no visual to draw. There would have to be a  visual in the 3d model (similar to a little weld object but specifically for a BOM entry) that you could click on to view the properties and edit but then you just attach that object to an assembly and it could show up on the bill of materials magically.
Idee einsenden
