Make the all the model tokens in drawing usable
We have many tokens in the model DWG file for use, but they are not all usable in the drawing. Unfortunately, it is not possible to use all these tokens, for example in the corner stamp of a drawing generated from the model.
An token example, where it doesn't work in the drawing: %ModelName
Example of  use in the model DWG file - get the model data name and can use it to generate a part of the drawing file name (model DWG file name = Test.dwg, internal drawing no. = 01 -> e.g. drawing file name = Test 01.dwg)
External possibility of the use out of model data: in the drawing stamp without drawing no. (01).
Overview of all available tokens, located in Management Tools / AstorBase/GenericStringToken, see Attachement.
2 Kommentare
bigcarl5000kg
bigcarl5000kg
It seems that since AS 2021 it is already in much better condition - you completed one task in Autodesk in advance :grinsendes_Gesicht:.
Just go on..
Idee einsenden
