Hi All,
Just a couple of simple ideas that I think could save a lot of time with edits/re-edits:
- When grip editing dimensions (a really useful feature), the drawing updates reverse this change and either delete the gripped dimension or re-instate it to its original position. It would be really handy if grip edited dimension points would also "lock" into the new position.
- We consistently have sections (cut views) created in the details which are similar. That means we are having to dimension/edit essentially the same or similar items over and over:
- A tool to copy dimensions around the drawing would be handy. These would have to lock to the new (destination) element and be able to be grip edited as per item 1 above.
- Similarly, a tool to copy labels and behave in a similar manner would help a lot. The copied labels should "lock" into, and inherit the properties of the destination element as well.
Hope this can be considered as I think it would save a lot of time in edits.
Dart
