Make a difference between local clip at corners and contour dimension
As shown on pic 1, local corner clip dimension is combined with a contour dimension. Contour dimensions have to be clean, end point to end point, and
not mixed with local clips at corners.
Pic 2 shows diimensins modified the way they are supposed to be.
There should be a difference when dimension is recalled if dimension is a contour dimension (even of the contour is not a rectangle) or a local (clip, secondary) dimension.
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Under Review
haedicu
Status geändert in: Archived
Due to a low support of your peers, your great idea is not considered for implementation at this time. Thank you for your contribution, every idea has merit. We always encourage you to rework and resubmit these ideas based on feedback received.
Idee einsenden
