Make a 3D CAD from Advance Steel - add parameters & relationships for 3D design
Full 3D functionality for all constructions is expected from every 3D CAD. The main principle is - define all components in the 3D area so fully geometrically, that you could change the partial / entire geometry at any time and the relationships between the objects are always preserved.
This BASIC 3D parametric functionality is unfortunately not available in Advance Steel - you cannot create a free, fully parametric 3D construction. We definitely want to use the parameters and relationships for spatial constructions in 3D.
The existing parametric modules are strongly object-specific and cannot be used for all other possible constructions.
We didn't want a hibrid system, we want a fully parametrically controllable system. Please, turn the Advance Steel into a 3D CAD, support our daily work and your future. You can move the Advance Steel where it really belongs.
2 Kommentare
ChristianBlei
HI,
is this not the road to inventor?
Also, you could do a lot coding or using Dynamo if you are able to create Dynamo nodes.
BTW, what industry are you working for? What type of constructions do you design?
Nicht anwendbar
Hi @ChristianBlei ,
Inventor is not suitable for steel construction, such a transmission and mobile tower. Good example is Tekla Structures, but .... :zwinkerndes_Gesicht:.
I already have experience with real 3D CAD (such as SolidWorks, ...). The 3D CAD must make it possible for the user to create free parametric constructions including a relationship in the model space. Otherwise it is not a real 3D. This would greatly simplify the work of Advance Steel
Idee einsenden
