If you create a baseplate you can also create a leveling plate. However the settings you can fill in are dimensioned from the baseplate. It would be nice if there is a possibility that you can fill in the setting from the anchors. the outside of the concrete is also measured from the anchors. Now i have to manualy calculate what the dimensions have to be.
Regards
