Level symbols
Level symbols
hi,
it wood be nice if the value in level symbol can be added with user text, like we now have in dimension lines.
4 Kommentare
haedicu
Status geändert in: Under Review
DumitruBerteanu
Status geändert in: Accepted
bullit2312
There should be an option to add prefix text to the level symbol. eg. FFL, TOS, TOC etc.
I know this can be done through drawing style manager but it is hugely over-complicated & still does not produce the desired result.
It should be much simpler, ie double click the text & add the prefix. This should take 2 seconds maximum.
Tags (3)
eugenezamula
Currently, there is only one option to set a  default prefix/suffix in the management tools which is not always appropriate. One drawing may require multiple different references like TOS, BOS, TOC, SSL, FFL etc. The level symbol must have Advance Properties to add prefix/suffix.
Autodesk, please make more effort to improve the software. Every year you release a new version with minimum updates.
Idee einsenden
