There are a few things that would help if labeling of slotetd holes can be better developed:
1. As previously submitted-frame in label shall follow the direction of the slotted hole-this is a common shop practice that is not incorporated in Advance
2. When manually labeled, slotted holes are dimensioned as round holes-with diameter only, not including the length, this is now done by entering the token length, deleting the diameter symbol, and adding x between diameter value and length, and adding frame at the end, and also s0ometimes rotation the frame 90 degrees to match the slot orientation.
3. Value for slot length shall not include feet, only inches.
Manual labeling shall recognise slotted holes and label them as slotted holes, not as round holes.
Ilko Dimitrov
