KISS MAPPING
KISS MAPPING
https://knowledge.autodesk.com/support/advance-steel/troubleshooting/caas/sfdcarticles/sfdcarticles/...
Why has this not been fixed yet? The post was from May 2015. It is now December 2015. This is absurd that it has not been taken care of yet.
Please fix this ASAP. Projects are starting to be late because it takes forever to map every new piece that we do.
2 Kommentare
haedicu
Status geändert in: Under Review
Thank you for your comment. We are looking right now into this topic and will come back once we have new information.
best regards
Udo
haedicu
Status geändert in: Implemented
this behavior was corrected with Advance Steel 2016 R2 release. Please make sure, that this is correctly installed on your side. The improvements will be also available with the upcoming 2017 version.
If you are still facing some issues with that export, please reach out to the support to investigate the issue.
many thanks and
best regards
Udo
Idee einsenden
