Joints (Macro connections) bolt orientation.
Please fix the bolt orientation in connection macros to always orientating the head of the bolt to the secondary member, or provide the option to do so, rather than inverted and non-inverted bolts.
The bolt lists are generated based on the bolt orientation; the head of the bolt being defining factor as to the item the bolt is assign.
This is creating a lot of duplicate joints, just for the bolt orientation, but the software should have the intelligence to base the orientation on the user selection when creating the joints. (member/item 1 {main support member} member/item 2 the secondary member)
Could the development team please fix the bolt orientation in all macros to always orientate the head of the bolt to the secondary member, rather than the cleat or Main supporting member.
Also in some macros, the invert bolt option doesn't always work as intended, and reverts the bolts back to the cleat every time the joint box/macro is opened, and doesn’t update all connections within a joint group. Due to the software inconsistencies, (software bugs) this make it difficult to manage the bolts and their assigned members or assemblies when bolt are within a macro.
3 Kommentare
acbsdesign
Yes, Please!
If we have shear plates with slotted holes, washers are supposed to be located over slotted holes, the head is always at the beam.
This is the way it should be done automatically.
@Austruct
Thank you for your input.
Flies-Eyes
Better still just give us access to the macro coding so we can fix it ourselves. History would indicate that actioning any requests to resolve functionality to the existing system is not of interest to shareholders.
I would need to check to see if converting a library macro to a custom joint would resolve.
acbsdesign
Better everybody to stick to their scope of work and do their job, me doing someone’s job it is not the right way, my job is to produce, suggest and pay.
Idee einsenden
