Using the Connection Vault in Advance Steel, I am attempting to use the macro called Joint for Stairs - Angle at the Top. When trying to bolt an angle to the main member and weld it to the secondary member (as that it will be an attached part on the stair stringer main part), the connections are created, but the weld is always a site weld. I desire a shop weld here, though the macro doesn't seem to contain the option. The only way to correct this is to physically change the weld itself (after exiting the above named macro), in the welds Advance Properties. I believe this to be an oversight in the development of this particular macro.
