Joint Box Restore
Joint Box Restore
It would be nice to be able to restore or reverse engineer a joint box if it has been deleted and gone unnoticed.
By selecting all the beams, plates, welds, features and bolts that are associated with the joint the system working out what the joint was based on model roles for the items.
For example in the image the Fin Plate connection has named the shear plate so could work out that it was a Fin Plate connection.
3 Kommentare
advandes
I accidentally deleted my stair connection box, and now I can't change the stair after I have already spent quite a bit of time working on it. Is there any way to restore this in version 2023?
johnjmbennett
Only thing I can think to suggest
If you only just did this, then go and look in the temp folder to see if there is a auto save file, from the last time it was saved.
You may lose a bit of what you are doing, but it should be there
advandes
Thanks John,
Unfortunately I had saved the file with the deleted connection box, but fortunately I had the stair finished except for a slight detail at the landing, so I was able to continue with what I had. If this happens again at least I have your idea...Thanks again!
Idee einsenden
