Joint Box Lock
Joint Box Lock
Joint Boxes to "lock" automatically so cannot be deleted unless you unlock them.
2 Kommentare
I mean, maybe not a bad Idea, but here's an additional idea:
 Create a default if the delete command could delete joint boxes. If this setting is set to false, only a special command will delete the boxes.
I think up to now it should be enough to set the layer to off (not freeze it lock it). So you could open the joints by using the advance joint property in the context menu of each item. But it could not be deleted, because of not selecting it
mick-CNF
@Sebastian_Eiche
Changing this a little bit due to an issue I'm having now with joint boxes randomly deleting as groups.
If there was a "Lock box" to check but also if it is the primary connection, it locks the whole group.
Idee einsenden
