Intelligent Dimensioning of a hole pattern
Default Plate-Assembly Dwg StyleDefault Plate-Assembly Dwg StyleModified dimensionsModified dimensions
Plate Assembly Dwg Style:
Advance Steel handles well hole pattern if it is done along X and Y ordinates, but it lacks the dimensions along rotated hole pattern at any angle.
1. It would be helpful if sloped hole pattern is dimensioned as it is shown on the screen shot to the right.
2. It will be even better if ANY hole pattern is dimensioned by clicking on a reference point and on the first hole-rest to be automatically added to the dimension chain - this will be a great time saver.
(this applies to ALL dwg styles)
Also-possibility to automatically group equal distances.
Ilko Dimitrov
4 Kommentare
Meanwhile, I can recommend you to switch the dimension rule for Plate Assembly style with "4 - Sp Gusset Plate" for these situations.
It will get you closer to the expected output when it comes to dimensions .
Grouping of automatic dimensions is available for each dimension chain via DSM.
Regarrds
Gabriel Costin
acbsdesign
Hi Gabriel,
Yes, I changed the MP Plate dwg style rule to SP Plate when I installed the latest version.
Do you know if there is an existing documentation describing the symbols used in the dimension definitions?
Thank you.
Ilko Dimitrov
Hello
You can use List of Abbreviations for Dimension Strategies as reference.
The names aggregate the settings that are part of rule (as software perspective). However, you may foresee info that will help you to identify and understand the dimensions.
regards
Gabriel Costin
acbsdesign
Thank you, Gabriel.
Idee einsenden
