Individual Position Numbers for Bolts/Washers and Nuts
Well, like the subject says, it would be really necessary to give Bolts, Nuts and washers individual position numbers.
Currently it is only possible to give the complete bolt assembly one position number. However, this is usually only done with bolts according to DIN 6914 (because you can buy these bolts only as a set). Every other type of bolt, nut or washer you have to order separately, therefore you need a individual position number for those parts... otherwise the procurement department will not be able to order anything. Currently this is done manually for each bolt assembly.... and this costs a lot of time and money. I don't know how the other companies deal with this issue but in our understanding this is a basic feature which every steel construction software should offer.
This is what it could look like. I'm aware that you have to consider also 2nd washers, 2nd bolts etc....  so it probably is a little bit more complex than this, but I think the point what we need is clear.
4 Kommentare
krnavek
It is very old wish/request.
Status geändert in: Future Consideration
We will have a look at it.
Gernot
ChristianBlei
Hi Manuel,
you can do that with a post edit.
You need a database with the part  to item number relation. Then all you have to do is analyze the bolt sets. You can add that info to the bolt label (somehow).
Christian
Julio_Soto
Having to do this manually is not a great option. Like you said, it seems any steel software worth its salt should have this.
Idee einsenden
