Improve both BOM types-scripting in both types- result of a script as token
  1. the functionality of external BOM (Active Reports) and BOM on drawing(dwg) should be identical.
  2. Instead of using a formula that is very limited in its functionality and a scripting version whose result cannot be used as a token (opposed to a formula) VB Scripts similar to the scripts for Detail Styles and Processes should get used to create the data in the data field. The result of such a script should be accessible as a user token in addition to the exisitng tokens. This way most of what is asked for as improvements in BOMs in the idea station could get created.
Idee einsenden
