Improve aesthetics in labels
Ugly Mess 08 15 18Ugly Mess 08 15 18
Hello, ref. screen shot above, please make labels positioning more intelligent, there was an extensive request for leaders for labels for holes to be centered to the hole center, offset with radius amount, please also include angle of labels as a parameter, (15 degrees increment) the picture above is so ugly especially if we have to clean this 1000+ times a day. Please also do not tell us this is happening ONLY with our installation, or workstation, or country settings, or video card etc. I would ask also for a change of your attitude regarding the aesthetics of the final product, these have been heavily neglected. Other example-Call-out detail-the text detail title and call-out text alignment issue.
4 Kommentare
acbsdesign
In this case, label for punch mark is located on the other side. It should be on the same side. Label for the plate would look best if located at top right corner, at 45 degrees.
Because angle for leaders is not incremental, it is harder to make them parallel to each other,
aesthetics would be much better if leaders are all at 45 degrees by default.
In very rare occasions 30, 15, and 0 degrees would work better, but this is only when there are 10-15 labels required in one detail.
acbsdesign
Labels overlap symbols.jpgIn this case labels overlap the grating span direction symbols. I would kindly suggest dev's to leave at least 3/32" distance between them. Fine tuning that it has to be done.
acbsdesign
Labels overlapped 09 10.jpgAnd another example how labels overlap-these have to be more intelligent, to be located following simple logic for distance to element, angle of leaders when leaders are present, and not to overlap. I do not believe I am asking for something that cannot be done, or for something that all of my colleagues wouldn't benefit. It will improve aesthetics and reduce detailing time.
acbsdesign
Labels too lcose to element.jpgIn this case text is too close to the bent plates, STAIR UCS dwg style is used.
Idee einsenden
