Import drawing style-process
When importing a drawing style or process, improve the import option to allow merge feature against existing line/field entries. Like if you copy a file and it is the same you have option to keep both, use existing, overwrite existing.
Thus remove need to clean up data entries that are left behind by the compact and purge feature. This process does not always clean up entries, end up manually swapping them back, the removing from the various relative tables.
Same when copying, inside the DSM, give opition to compare/ replace / copy of etc.
2 Kommentare
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
Bogdan.O
Status geändert in: Archived
Thanks for taking the time to submit your idea and to everyone else for contributing your thoughts and votes.
Unfortunately, this idea could not be included on our road map and as such we will not be pursuing it in the near future.
Thank you for your understanding.
Idee einsenden
