Icons for shortcut
Icons for shortcut
It seems like on every new advance steel release, a lot of work is devoted to changing the way the program looks and all the icons go through a major update. However, for some reason, the actual AS shortcut icon never changes, which means we need to be very careful on starting Advance as there is no visual way to distinguish between AS versions. IMO, this is much more important, especially during the transition periods when you are finishing a project in an older version and starting a new one on the latest.
So, the request is if we could please have the Icons to the Advance steel shortcut updated/changed with each version so we can easily identify which version we are running?
Idee einsenden
