Gusset Plate to Column and Beam - add shear plate option
Per attached screen shot, in 99% of all gusset plates to column and base plate macro-when macro is used to column and beam, gusset plate  has to be connected to the HSS / Pipe column with shear plates.
Currently the macro has an option to add a plate, but it is for wide flanges columns only-plate is perpendicular to the gusset plate.
Sometimes for W-columns and always for  HSS / Pipe columns plate has to be oriented as a shear plate, bolted to the gusset plate and welded to the column.
Please include this if possible.
Ilko Dimitrov
8 Kommentare
acbsdesign
And a screen shot when it is done, with slotted holes in shear plate, std holes in gusset plate.
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
acbsdesign
This is another example, used by designers very often-gusset plates to 2 beams connected with shear plates.
Option for slotted holes in shear plates will be great.
acbsdesign
And this is a screen shot from below.
Nicht anwendbar
Has this been created yet or has anyone found a workaround?
Thanks.
acbsdesign
Hello Peter,
I Have created a few custom connections using the "Beam and point" option, point is the end of the bottom flange at the edge of the gusset plate.
Connection includes the shear plate and the bolts only, gusset is created using the out of box macro.
It is a time saver.
Ilko Dimitrov
ACBS
Nicht anwendbar
I will have to try that.
Thanks Ilko!
best regards,
Peter
acbsdesign
Any time, Peter,
It is a shame the custom connections does not allow us to have folders in it, my custom connections folder gets overcrowded, and I ended up creating 3 folders in it-Misc. Metals, Structural and Bridges. When I need a custom connection, I move the dwg file outside of the folder to be able to see it.
It is a WWII workaround, hopefully devs will improve it.
Ilko Dimitrov
ACBS
Idee einsenden
