Grouped dimensions to stay at the center between dimension lines
Per attached screen pic, grouped dimensions snap to the left dim. line after grouping, they overlap the adjacent dimension from the same dim chain, it will be helpful if they stay at the center between the two end dimension lines.
Ilko Dimitrov
2 Kommentare
haedicu
Status geändert in: Implemented
i wasn't able to reproduce this behavior. On my side the text is centered right away.
If you reproduce this regularly on your side in different drawings & projects - please clarify with support.
Many thanks and best regards
Udo
acbsdesign
Hi Udo,
Suport is very slow annd the chain is usually broken over the Atlantic.
This issue is typical all the time-dimension gets to to one side, overlapping the adjacent dimension.
Ilko Dimitrov
Idee einsenden
