It would be great to be able to choose double side hatching on a grate. I know you can set hidden line to achieve this but you don't always want hidden lines turned on.
On a recent project I had to show the hatching on 3D views (see attached) as well as dimensioned elevations from the outside so it was necessary to change the topside and then create the next drawing. This took considerable time and was an even bigger pain in the neck when the client changed details 3 times. A simple switch in the properties to allow for double sided would be great that works in conjunction with the topside switch because that is important.
