In the Drawingstyle manager there is a setting that gives a result that manual place holes are not dimensioned and holes from bolts are dimensioned.
This is working fine. See attachement . But if i create galvanizing holes in a macro (also just only holes and not from bolts) you espect that these holes are getting also no dimension. But this is not the fact. (see attachement)
So why do manual placed holes do net get a dimension en galvanizing holes from macro's do get a dimension?
My wish is that the setting Holes will listen to only the holes without bolts. And that "holes from bolts"are just holes from bolts and not galvanizing holes.
regards
