Galvanizing holes - Differentiate holes for dimensions
hi,
in many ways we use galvanazing holes, one time within a macro, another time manual made holes for galvanazing.
And offcourse we want these holes with dimensions on single part level but on assembly level it is another thing.
In assemblys it is not necessesary that these holes are represented with dimension.
So if it is possible to make a process or a new name in the holes such as "galvanazing hole" (in the line "round hole" "slotted hole" "treaded hole" etc etc)
and then in the drawing style manager dimension a selection switch for "no dimensions for galvanazing holes".
attached a picture with an example.
This saves a l;ot off time cleaning a drawing.
6 Kommentare
Nicht anwendbar
But it is nice iff the galvanzing holes function is availeble in many connections and not only a switch "galvanazing holes", if we can give dimensions where we want those holes like we place a bolt group in a connection.
thanks for considering.
haedicu
Status geändert in: Under Review
haedicu
haedicu
Status geändert in: Future Consideration
Nicht anwendbar
Maybe it is better that there will be a possibility in the drawingstylemanger that there can be created a sepperate dimension line for different holetypes.
TvdH1981
Also for punchmarks and such. I dont want them to be dimensioned in assemblys.
Idee einsenden
