GA PLATE
GA PLATE
Can we separate family of GA plates. Currently we have to do manually in BOM?
6 Kommentare
could you describe it a bit more? I'm not sure what you want to have
anshulgupta861
Like if we want to place some GA plates in model, i find no option
where i can select 12,14,16GA etc plates so that same can reflect in BOM
also. Instead i have to put thickness of that GA plate in model and it
reflects PL1/8 in BOM and i have to change it manually. So it will be helpful
if there is some option to select GA plates in Plates family.
I hope i managed to describe properly.
Thanks.
Maybe a few sceenshots would be helpful.
If I understand it correct, the option for you is to use "variable gratings" for this. You could add different hatches and in the databases the thickness could be saved.
For Selecting them, the filter of Advance Steel should be used. These could be saved and seen in the Project Explorer to reuse these filter in each situation.
anshulgupta861
@Sebastian_Eiche
I thinks it should work for me in normal GA plate.
But what to do in case of stair tread pan, if want
12GA tread pan, how can i select in this case,as i
did in variable grating by adding profile in database.
if you want to use it as stairtread, specialparts or userprofiles are maybe better.
anshulgupta861
Thanks @Sebastian_Eiche
Idee einsenden
