Free remark to overwrite section name.
I would like to be able to overwrite the name of a section with the free remark. This would be similar to how special parts are named. You can either use the name of the block used for the special part or overwrite it with the "free remark". I would like to be able to do this with sections, plates. bolts, studs, and anchors.
I have been using AS for over 10 years and I seem to remember that this was possible back in the early versions.
2 Kommentare
olivier_gervais
Hello pinnacledrafing,
This is already possible using the "mapping" option you can populate external,2,3,4 from the table MapInterntoExtren from the AstorBase. you must enter the beam size name as the Internal value then you can map it to what ever you want even an ERP system for example. These External name can be use in titles and labels as well and the list of course! :leicht_lächelndes_Gesicht: If you want to use the mapping external as a priority over the beam size, you must check the "mapping" option from the management Tool defaults. If you look into the table MapInterntoExtern_SteelOffice you will see that you can map bolt as well.
Cheers,
pinnacledrafting
Thanks, Olivier.
I was thinking more of a once in a while type of situation instead of a permanent solution. I should have made that clear.
Bill
Idee einsenden
