Four Diagonals - Middle Gusset Plate needs help.
The macro for Four Diagonals - Middle Gusset Plate needs some fixing. First, I need to be able to tell my fabricator what size to make the plate, not let the intelligence decide for me. My fabricator does not want to cut a plate for this to 1/16ths of an inch. I was able to jockey around the projections to get it to be to the nearest 1/8", but why can't I tell it to be a size? There are two lines, #9 & #10 in 'Projection of the Gusset' that are always greyed out.
Also, when I enter the edge distance under "Bolt Distances - diagonal x", #1 distance diagonal, on the model the distance is 1/16" less than what I want! When I over-adjust to get my edge distance, I have to go through the projections again to get to a happy plate size. Which is why we need to be able to input that plate size ourselves, not let AS decide for us!
It shouldn't EVER be normal to do trial and error on a connection like this. Another huge time eater.
Idee einsenden
