Folded plates - add more logical funktionality
Add useful functionality for the folded plates:
- currently complicated transitions on sloping edges with complicated forms in the bending area
- automatic standard cut-outs in different forms (square, circular) are missing
- add the processing through the bending area after bending (corner cut, bewel cut, ...) - enable this for the Display type "unfolded"
1 Kommentar
bigcarl5000kg
Add the option of automatic dimensioning for shaped bend plates too - contour points, bend axis = add recognition of all contour and bend points for dimensions
Idee einsenden
