Fix the SLICE tool Hotkey
When I type in "sl" to use the "SLICE" tool and hit enter, instead of the tool becoming active I get this line "Command: SL
(12 120 12 89)(12 120 12 89)".
See attached image that shows "SL" above "SLICE" in hotkey window.
4 Kommentare
mick-CNF
I don't think the slice command will work with AS objects only 3D solids.
If you need to slice an AS object use split beam or split plate.
Nicht anwendbar
Well it's a good thing I'm talking about using the slice function on 3D Solids. Also, the slice function works. It's that to use it there is an unnecessary keystroke required for this command.
mick-CNF
Are you saying the slice command works with AS objects?
It doesn't work for me with AS objects.
I know it works with 3D solids, it is a command in 3D modelling but not in AS.
Craig.Brownlie
I also find this frustrating. Advance Steel should not break basic Autocad commands.
Idee einsenden
