You can set up both the rollover tooltips and quick properties in the CUI to show you information about items in advance steel like name, coating, material.... pretty much whatever you want. But it doesn't always work. For some reason it quits working and upon returning to the CUI you find the original checked boxes for your desired information and now there identical boxes (unchecked) in there as well. 2 "name" boxes, 1 checked, 1 unchecked. So you check the second box, it starts working again, only to stop again later. Go back into the CUI and now there are three boxes. "name" checked, "name" checked, "name" unchecked. This could go on forever. It needs to be fixed. It's very helpful, when working, to rollover or single click select and beam to see some info without having to double click into the advance properties.
