Fix for .nc files not creating properly V2022
There is a post about .nc files not creating properly the second time, when model is on a network path.
"Can't write the NC file...writing file failed" when exporting NC files second time in Advance Steel...
The command for the example is _AstM4CommCreateNCByStyle 1 which works for us on the network (for v2022) we cannot however run the command _AstM14CommCreateWisconNC. We need to be able to do this, we were able to in version 2019.  Is there a fix for this besides drive mapping?
1 Kommentar
wslomiany
correction, after the second try, _AstM4CommCreateNCByStyle 1 does not work as well as outlined in the A/S support.
Idee einsenden
