extra hole tolerance bolt/hole
hello
when I put a bolt I can choose the extra dimension for the diameter of the hole. This is a teoric parameters. It is "true" for hole make with drill but when if the hole is make on a plate cutting with oxifuel or similar hot process it can be "false" because the true hole is more small. Maybe I need a different value of the paramater only for the machine. I want ask if is it possible to have an automatic parameter to set  this extra when I put the bolt. This extra must be used only for nc/dxf file for the the cutting machine. The shop drawing of the  plate maybe create with nominal dimension or "machine" dimension (with extra) or with all two dimension.
thanks
bye
Idee einsenden
