Export to STEP
Export to STEP
Over and over again we must export Advance Steel models in STEP.
The workflow in addition is very costly.
First one must explode the Advance Steel model in volume body, then export the exploded model with AutoCAD to ACIS and then export the file ACIS in STEP with another programme.
It would very make sense if Advance Steel had a direct export to STEP.
Regards
Elias
6 Kommentare
ETheuring
Hello FelixT,
Have you read my text?
Nevertheless, this is the problem what the users have.
Absolutely one can take another programme / Converter.
But, nevertheless, direct export would be much easier and quicker.
It is surprising anyway:
In AutoCAD one can import since several versions STEP files.
Unfortunately, one cannot export them there.
Why this export is not implemented in AutoCAD?
Regards
Elias
ETheuring
This is clear to me!
ETheuring
 However, it would be good if you could put your voute. Since the more people find this also good, the faster it comes to the software.
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
Nicht anwendbar
AutoCad Mechanical has been able to create stepfiles for a long time with the command "stepout". Why this does not work with Advance Steel - I don´t understand why! We need this function urgently and quickly!
Nicht anwendbar
Ich habe dann auch heute herausgefunden, das in Advance Steel ein Step-Export nicht möglich ist.
Für die Anfrage von Kant-Laserteilen ist dies aber unbedingt notwendig.
Nun werde ich wohl versuchen müssen, über eine AutoCAD Mechanical 2005 - Lizenz irgendwie den Export hinzubekommen.
Leider verstehe ich nicht, wieso dies in Advance Steel nicht implementiert ist, das Step-Format kommt doch inzwischen relativ häufig vor.
Selbst "einfache" CAD-Programme besitzen diese Schnittstelle!
Daher  ===» Bitte kurzfristig einbauen, viele Nutzer benötigen diese Funktion!
Regards
Elias
Idee einsenden
