Export to coordinate
With the adoption of BIM lots of main contracts are now stipulating that all exports, IFC, 3D DWF, CIS/2, 3D DWG are exported to coorinate points.
The points can be 100's of KM from the model 0,0,0 so it is not feasable for the user to model at the points.
AutoCAD already has the BASE command where users can set coordinates when inserting into other AutoCAD platforms - https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2021/ENU/AutoC...
Please add an option to ALL exports where users can export to the BASE point if it has been set
This would be similar to functionality available in Revit - https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
Idee einsenden
