Exploding Advance Steel to AutoCAD drawings
When exploding Advance Steel drawings to AutoCAD drawings the dimension explode into lines, etc.
There needs to be a way to explode to AutoCAD drawings without exploding the dimensions.
I have done a work around to turn all the dimensions into a block first then explode them through the Document manager. I open the exploded drawing the the dimensions stay as a block, then I just explode the Dimensions block and it stays as dimensions in the drawing.
Please provide a solution to this issue.
Idee einsenden
