Explode to ACIS enhancement
Dear Advance Steel Dev Team,
Very often it happen, for steel structures with pipes, that we have to give to the producer an ACIS file, that have to be "read" by the laser cut machine. This file have to be saved with the position name of the single part and have to include only the single part.
Now I do it in this way: using the "_wblock" command I save the single part with its name as acad block, then I open it and use the Advance command to explode to ACIS each single file.
It could be a very useful tool if we have the option to export as acis file all the selected parts, automatically saving each single part separately with filename identical to the single part position name.
Hope to see this idea in the next releases of Advance Steel, cheers.
5 Kommentare
ETheuring
Hello, Stefano,
with whom have you shopped Advance Steel?
With Graitec?
Graitec has developed for Advance Steel a Plugin, the Graitec Powerpack for Advance Steel.
The Powerpack contains exactly this function which you need.
If you have purchased the Advance Steel with Graitec, you receive the Powerpack free of charge in addition.
Otherwise you can purchase the Powerpack about the Autodesk to ext. net curtain: https://apps.autodesk.com/ADSTPR/de/List/Search?isAppSearch=True&searchboxstore=ADSTPR&facet=&collec...
Regards
Elias
iwafb
This is a fairly common process/request and should be incorporated into Advance without the need for extra expense or plug ins.
Nicht anwendbar
We have self made command for this :
https://knowledge.autodesk.com/community/screencast/38ab41be-daeb-49f0-9325-2f9b3f1e006a
It reconstruct folded plate to have only one solid per plate
Contact me if you want dlls.
Bye
haedicu
Status geändert in: Under Review
We will be further evaluating this one in the near future and will keep you posted if we need any additional feedback or clarification. Please feel free to continue voting on this one as it will help us with the continued evaluation.
Bogdan.O
Status geändert in: Archived
Thanks for taking the time to submit your idea and to everyone else for contributing your thoughts and votes.
Unfortunately, this idea could not be included on our road map and as such we will not be pursuing it in the near future.
Thank you for your understanding.
Idee einsenden
