Explode tapped holes with value of drilling hole not diameter!
Now when exploding parts with threaded holes into ACIS-Objects, the threaded hole gets the diameter of the value diameter. But for threaded holes that makes NO sense. Would it be possible to just add a option in management tools for example like: Explode threaded holes with 1. Diameter 2. drilling hole.
I don't know if it makes senso to others, but i never needed to explode threaded holes with their outer diameter.
Also that AS continues to work as always, the value can be default 1.
That would be a critical feature needed ASAP, not in any (maybe) 2024 release! Maybe with a hotfix for 2021/2022?
Idee einsenden
